cganne's avatar
cganne
RBK50 Not blocking on school Mac Air
hi,
I have this RBK50, able to block the traffic and able to control on every device on my home, except the school Macbook Air given by my kid's school. Parential control works very good on rest, even on my wife's work laptop.
How can I control it on my son's laptop? what type of logs can I extract and give you folks to see where the problem is. I thought of asking the school people to take their laptop or give me full control.
Thanks for your time and appreciate any solution.
I use Circle app and did profiling and filters there. I also went to router configuration and entered the site name to block and its not doing anything. All my products are uptodate.
  • CrimpOn's avatar
    CrimpOn
    (Not using Circle myself, but....) How does Circle identify a device that should be managed?  (Is it by MAC address?)
    The most recent Apple software versions have a feature to create artificial MAC addresses rather than use the actual hardware MAC address. It is an option that can be turned on or off.
    There is a community forum specifically for the Circle product where users may have personal experience to share:
    https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
    • cganne's avatar
      cganne
      Thank you very much for your reply. I'll chk that route. Since its a school laptop..I do not have access to change any, but will try.
      Yes in circle I identify it by Mac and the name and assigned it to my son's profile.
      • CrimpOn's avatar
        CrimpOn
        Might be worth verifying that the MAC address remains the same every time the laptop is connected to WiFi.
        There are numerous articles on the web showing where in iOS this feature can be disabled, such as:
        https://help.firewalla.com/hc/en-us/articles/360055342613-How-to-turn-off-MAC-Address-Randomization-
        The school obviously has to allow users to access some parts of the WiFi settings so that they can log onto their home WiFi network.
