808_networker
Mar 24, 2018Follower
RBK50 paired with Two RBW30
I see some mixed discussions about adding the RBW30 plug-in satellite devices to a RBR50 router. I do not see this combo in any of Netgear's Orbi pre-packged device combos which leads me to beleive t...
- Mar 25, 2018
The RBW30 satellites are supposed to work with the RBR50 router. However, the backhaul of the RBR50 is 1.7 Gbps and the backhaul of the RBW30 is only 866 Mbps, so you would not be taking full advantage of the RBR50 if you use the RBW30 satellites.
st_shaw
Mar 25, 2018Master
stangebelm
Apr 01, 2018Guide
Das Zusammenspiel ist überhaupt kein Problem! Läuft!
- DarrenMApr 02, 2018Sr. NETGEAR Moderator
Hello Ulairi
We have released the latest firmware on the auto update server you may try updating all your your units and see if the 30 will stay connected.
DarrenM
- UlairiApr 02, 2018Luminary
Hi DarrnM,
Thanks for that heads-up. I've updated the Wall Satellite from V2.0.0.34 to the new V2.0.1.2 and - so far - all good! No dropouts.
NB - I've got both the RBR 50 router and the RBS 50 satellite at V2.0.1.4 (downgraded from V2.1.0.18 and not yet updated to V2.1.3.4 because I haven't had problems with dropout and don't need the wired backhaul). So this is confirmation that these two versions (V2.0.1.4 for router and V2.0.1.2 for the wall satellite) seem to be compatible.
DarrenMwrote:Hello Ulairi
DarrenM
To
- UlairiApr 07, 2018Luminary
Well, the problem is back again! After three days of no issues, my son's iPhone couldn't connect again. It was saying "no internet connection". I suspect that the fault either doesn't occur until he roams into the wall satellite's coverage or something build's up in the unit over time (memory leakage?).
I turned the RBW 30 'off' at the wall and he got connection immediately.
I remain of the view that the RBW 30 is completely unusable with the RBK 50 setup. My advice to the original poster is don't buy anything other than another RBS 50 satellite to extend the RBK 50.
