808_networker
Mar 24, 2018Follower
RBK50 paired with Two RBW30
I see some mixed discussions about adding the RBW30 plug-in satellite devices to a RBR50 router. I do not see this combo in any of Netgear's Orbi pre-packged device combos which leads me to beleive t...
- Mar 25, 2018
The RBW30 satellites are supposed to work with the RBR50 router. However, the backhaul of the RBR50 is 1.7 Gbps and the backhaul of the RBW30 is only 866 Mbps, so you would not be taking full advantage of the RBR50 if you use the RBW30 satellites.
ovq
Apr 15, 2018Guide
Hi!
I understand the limited baclkhaul between the 50 and the 30, and it would be OK for me.
My question is: will connecting a 30 limit the backhaul of the entire system, i.e. also between the two 50s?
Ulairi
Apr 15, 2018Luminary
ovq wrote:
Hi!
There's a few threads on this topic on the forum (search for 'RBW30'), but as far as I'm aware no definitive answer has emerged. This one has some good info, with the real world factors to also consider: RBW30 Backhaul
- ovqApr 15, 2018GuideThank you. I guess in order to keep the max backhaul speed it’s safe to say that I need another 50, I guess.
