ericsammons
Oct 16, 2018Aspirant
RBK50 Router losing internet connection after upgrade to V2.2.1.210
Hello,
Recently I've been experiencing issues with my internet connection being lost about 2-3 times per day. In the couple years I've been with this ISP, I've never had an issue. At first I ju...
Oct 16, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Also Try this:
ericsammons
Oct 17, 2018Aspirant
Unfortunately, my ISP puts their modem in a locked box on the outside wall, so I can't see the manufacturer information.
Before I saw your message, I decided to downgrade the firmware to V2.1.4.16, and after about 20 hours I've had no lost connections. At some point, I'll try to upgrade again and enable Daisy Chain, but hopefully, Netgear will fix the firmware, if that's the problem.
- FURRYe38Oct 17, 2018Guru - Experienced User
Ok, please try a FW upgrade if you get time and Enable Daisy Chain. NG is aware of this problem.
