Randnik_2017
Dec 15, 2017Tutor
RBK50 satellite down to 2.4 Ghz connection to router
Dear all,
Last week the satellite went down in its primary connection to the ORBI router to a 2.4 Ghz connection permanently.
I tried all the hints here I could find in the forum: rebooting both devices several time, factory reset and complete new set-up with the ORBI satellite i short distance to the router, changing the country location etc. and today I installed the new firmware 2.1x on both devices but no change.
What to do? Could this be a hardware defect on the ORBI satellite?
thanks a lot in advance for comments / help
1 Reply
- DarrenMSr. NETGEAR Moderator
I suggest contacting support if it is a hardware issue they will be able to troubleshoot with you and RMA the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
