BillYoung
Nov 22, 2017Luminary
RBK50 satellite "no internet" status
to anyone who can assist: When I check for firmware updates on my router and satellite, the satellite reports "No Internet". What is it telling me? The only known change is the position o...
- Dec 06, 2017
Hello BillTYoung
I have had this issue as well I went and just power reset the units and may need to resync them. After that it allowed me to upgrade the firmware on the satellites.
DarrenM
DarrenM
Nov 27, 2017Sr. NETGEAR Moderator
Are devices connected to the unit still getting internet from the satellite?
DarrenM
- BillYoungNov 29, 2017Luminary
DarrenM:
Yes, devices that are connected to the satellite still get internet access despite this issue.
I put a tablet I have right next to the satellite, connected it to the network (the first time it has connected to this network), verified that it was connected to the satellite, then accessed the internet on it. I went to a page that is updated daily just to make sure that it picked up the latest one from the internet.
BillYoung
- DarrenMNov 29, 2017Sr. NETGEAR Moderator
You can try to resync the unit see if that will get that message to go away.
DarrenM
- BillYoungDec 01, 2017Luminary
DarrenM:
I re-synced the satellite. The satellite ring (which I can see now) flashed white for about 1 hour and 40 minutes (not sure how long exactly - I didn't check it all that often). Once it went out, I tried it again. No change in behavior. Still getting the "No internet" message when checking for new firmware.
BillYoung
