BillYoung
Nov 22, 2017Luminary
RBK50 satellite "no internet" status
to anyone who can assist: When I check for firmware updates on my router and satellite, the satellite reports "No Internet". What is it telling me? The only known change is the position o...
- Dec 06, 2017
Hello BillTYoung
I have had this issue as well I went and just power reset the units and may need to resync them. After that it allowed me to upgrade the firmware on the satellites.
DarrenM
BillYoung
Nov 29, 2017Luminary
DarrenM:
Yes, devices that are connected to the satellite still get internet access despite this issue.
I put a tablet I have right next to the satellite, connected it to the network (the first time it has connected to this network), verified that it was connected to the satellite, then accessed the internet on it. I went to a page that is updated daily just to make sure that it picked up the latest one from the internet.
BillYoung
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
You can try to resync the unit see if that will get that message to go away.
DarrenM
- BillYoungDec 01, 2017Luminary
DarrenM:
I re-synced the satellite. The satellite ring (which I can see now) flashed white for about 1 hour and 40 minutes (not sure how long exactly - I didn't check it all that often). Once it went out, I tried it again. No change in behavior. Still getting the "No internet" message when checking for new firmware.
BillYoung
- BillYoungDec 05, 2017Luminary
DarrenM:
I manually upgraded the router to 2.1.1.12. It worked without any issue.
I tried to manually upgrade the satellite to 2.1.1.12. It failed. I tried it on two machines. The first machine is hardwired to the router. It failed when I tried to login to the satellite as admin. It refused to take my password. I tried changing the admin password, to no avail. The second machine is wirelessly connected to the router. It took the admin password correctly. And it looks like the update works. But when I check the status of the satellite, it still shows as being at 2.0.0.74.
So I believe this issue is preventing me from upgrading the firmware. Now what?!?!
- aazDec 05, 2017Virtuoso
When you manually update, always do the satellites and make sure they are complete before the router.
You should still be able to connect to your satellites via your satellite IP http://192.168.1.xxx/fwUpdate.htm - just go directly to the firmware update page.
