DavidShawP
Feb 11, 2022Star
RBK50 seemingly dead?
I’ve got an RBK50 with three satellites. It’s worked fine for years but tonight it isn’t responding. When I reboot it the ring light never comes on.
I tried resetting by inserting a paper clip with it powered on but the power button light just stays green and never turns amber. Help!
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflashI appreciate the feedback. I tried both methods. It seems it's too dead even for these low level tools.
./nmrpflash -i en0 -f RBR50-V2.7.3.22.img Advertising NMRP server on en0 ... | No response after 60 seconds. Bailing out.
I guess I have to go buy a new router.
Sometimes it can take a few tries to get the timing right.
Another thing you can try doing is swap the power supply from the router with a satellite. Maybe its going bad and not supplying enough power to boot the router.
