Damit1
Dec 09, 2018Apprentice
Rbk50 speed issues
Hi there On last black friday, bought RBK50 in this great deal. It has arrived, but LAN speedtest (and I believe it affect wireless for both Router and Satellite) are not Ok. I use to get arro...
Dec 09, 2018Guru - Experienced User
What FW is currently loaded?
Do a factory reset with the base router. Wire connect a PC to the router and setup from scratch. Do not enable QoS, Traffic Meter and Access controls.
What are the wired speeds tests results with a PC.
Damit1 wrote:
Hi there
I use to get arround 940Mb with simple Asus router.
With Orbi router get arround 600Mb in LAN in the router..
Wifi near Router is arround 500-600Mb (not making any sense).
Router Mode.
Get a DHCP in WAN directly from ISP to orbi router, so no middle box to nlame here.
Latest FW V2.2.1.210
Any ideas?
Almost got a heart attack after buying this expnlensive Mesh.
Thank you
Damit1
FW version is 2.2.1.210.
I got Fiber 1G FTTH , with SFP to Rj45 converter and cat6 cable directly to NG.
Netgear support suggested downgrade version to 2.1.4.16.
Is there a known issue with current one that needs to be downgrade?
Didnt have the chance to just factory default both units.
Thanks
Thanks
- FURRYe38Dec 09, 2018Guru - Experienced User
Some have said the v210 doesnt' work well with 1Gb speeds...
If you downgrade, please manually install the FW file to the Router only. You don't have to downgrade the satellites. Do a factory reset on the router and setup from scratch and do a wired speed test with a PC.
- Damit1Dec 09, 2018ApprenticeTried downgrade.
Not made it through, as sooj as it got back on was auto update to latest.
I dont know which model, how can I check?
Is there a chance the Orbi cannot handel as main router instead of ISPs router?- FURRYe38Dec 09, 2018Guru - Experienced User
Is there a router in front of the Orbi router? If so,
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.You might try Option #3...
What does the Orbi say thats your model router? Look on the box or on the Routers web page. It's probably a RBR50, if so,
