Damit1
Dec 09, 2018Apprentice
Rbk50 speed issues
Hi there On last black friday, bought RBK50 in this great deal. It has arrived, but LAN speedtest (and I believe it affect wireless for both Router and Satellite) are not Ok. I use to get arro...
Mar 09, 2019Guru - Experienced User
When your moving the phone to speed test between the base and satellite, are you turning OFF the wifi on the phone first after you arrive at either location, then back on, then speed test?
You need to ensure the phone is connected to either base or satellite before testing. Turning OFF the WIFI on the phone and back on helps.
Stea1th
Sep 05, 2019Aspirant
any update on this?
I'm having the same exact issue, it is really frustrating.
