pdavid53
Feb 02, 2019Aspirant
RBK50 Syncing Satellite Does Not Work
I just purchased an RBK50 system. The router works great but I can't get the satellite to sync. I moved the satellite next to the router and I reset it with no results. The satellite blinks white ...
- Feb 04, 2019
So after doing a factory reset and hitting the resync buttons on the satellite and router, fails to get the satellite reconnected? if so, then there maybe a problem with the satellite and you would need to contact NG support and ask for help and information on this. Possible ask for an RMA.
pdavid53 wrote:
The light on top flashes off and on continuously. It never stops
michaelkenward
Feb 03, 2019Guru - Experienced User
Orbi takes its time. I assume you left it for a while.
I have never known something to take so long to do its stuff.
