pdavid53
Feb 02, 2019Aspirant
RBK50 Syncing Satellite Does Not Work
I just purchased an RBK50 system. The router works great but I can't get the satellite to sync. I moved the satellite next to the router and I reset it with no results. The satellite blinks white ...
- Feb 04, 2019
So after doing a factory reset and hitting the resync buttons on the satellite and router, fails to get the satellite reconnected? if so, then there maybe a problem with the satellite and you would need to contact NG support and ask for help and information on this. Possible ask for an RMA.
pdavid53 wrote:
The light on top flashes off and on continuously. It never stops
Feb 03, 2019Guru - Experienced User
After resetting the satellite and you get a WHITE led on top of it, hit the black sync button on the router then hit the same black sync button on the satellite. Wait for the top led to turn BLUE then it's connected...
pdavid53 wrote:
I just purchased an RBK50 system. The router works great but I can't get the satellite to sync. I moved the satellite next to the router and I reset it with no results. The satellite blinks white but is otherwise non-responsive. I would appreciate any suggestions on how I can get the system working
