pdavid53
Feb 02, 2019Aspirant
RBK50 Syncing Satellite Does Not Work
I just purchased an RBK50 system. The router works great but I can't get the satellite to sync. I moved the satellite next to the router and I reset it with no results. The satellite blinks white ...
- Feb 04, 2019
So after doing a factory reset and hitting the resync buttons on the satellite and router, fails to get the satellite reconnected? if so, then there maybe a problem with the satellite and you would need to contact NG support and ask for help and information on this. Possible ask for an RMA.
pdavid53 wrote:
The light on top flashes off and on continuously. It never stops
pdavid53
Feb 04, 2019Aspirant
michaelkenward
Feb 04, 2019Guru - Experienced User
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- ekhalilFeb 04, 2019Master
Since you have access to the router, please try to make DHCP address reservation for the satellite. The MAC address of the satellite is on a label on the bottom of the satellite.
