pdavid53's avatar
pdavid53
RBK50 Syncing Satellite Does Not Work
I just purchased an RBK50 system.  The router works great but I can't get the satellite to sync.  I moved the satellite next to the router and I reset it with no results.  The satellite blinks white ...
  • FURRYe38's avatar
    So after doing a factory reset and hitting the resync buttons on the satellite and router, fails to get the satellite reconnected? if so, then there maybe a problem with the satellite and you would need to contact NG support and ask for help and information on this. Possible ask for an RMA.
    pdavid53 wrote:
    The light on top flashes off and on continuously.  It never stops
