RickJo
Mar 19, 2018Aspirant
RBK50 Unable to use Orbi Traffic Meter feature to round up data by coonnection
How does one get to and use the check box and Traffic Meter feature described as "Round up data volume for each connection by"? It seems in accessible and unusable to me.
Mar 20, 2018Guru - Experienced User
This feature maybe something that hasn't been fully enabled by NG in the FW.
What version of FW are you using currently?
- RickJoMar 20, 2018Aspirant
My firmware:
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.1.2.18 No new firmware version available. - FURRYe38Mar 21, 2018Guru - Experienced User
This is sometihng I don't see with my router. I'm on a beta just up from v.18. Not sure if this is a feature that has been removed or will be or only seen on certain modem Orbi systems.
You might contact NG support and ask about this...
