Eric90i
Aug 17, 2021Star
RBK50 V2.7.3.22 internet dropping
I’ve been experiencing random internet drop out where the orbi’s do not have an internet connection, but the WiFi shows as still connected. The ring lights don’t appear to respond the the error either. I power cycle router and satellite to get them working again. It has happened 3 times over the past 4 weeks or so. Anyone have thoughts on what to try to resolve this?
Leaning towards the classic Furry factory reset as my first option. I have survived multiple firmware updates with no apparent issues though previously (no need to factory reset).
Does the top ring LED turn on PINK when the internet drops?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- It is the Pace 5268AC. Have not seen the pink ring light when I have seen this happen.
I did the 1 minute power off of the modem and orbi’s after reading your response. Have not noticed a drop so far, but it was not a very frequent issue, so I guess I will see how it goes for now.- FURRYe38Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
