Robanddee
Mar 03, 2018Aspirant
RBK50 with DLink DSL2870B VDSL Modem/Router - how to turn off DLink router
Hi, I recently purchased an Orbi RBK50 system to improve the WIFI in my home, I originally set it up in AP mode and everything works well, however in this configuration I cannot use any of the Orbi ...
Robanddee
Mar 04, 2018Aspirant
Thanks for your help, Orbi does have PPPoE settings in the web UI but I'm still unsure about bridge mode on the modem router due to the "no default route" message.
Until I can sort out the bridge mode on the DLink I have followed your advice and given Orbi a static IP which I've placed in a DMZ on the DLink.
Setup is now like this...
DLink IP: 192.168.1.1
DLink DMZ: 192.168.1.18
Orbi internet port IP: 192.168.1.18 (Static IP)
Orbi IP: 10.0.0.1
DNS server: 192.168.1.1
Orbi DHCP server: On
Does this look right? Everything appears to be working well.
Mar 04, 2018Guru - Experienced User
Yes, Looks good.
Ask your ISP for help and info on how to bridge modems or look up on D-Links support site or forum for help and info. Maybe in the user manual for the modem.
- RobanddeeJun 11, 2018Aspirant
Unfortunately this solution did not work, It appeared ok at first, however, the D-Link began rebooting itself over and over every 10 mins or so until I removed the DMZ and placed Orbi back into AP mode.
I had given up for a while - but have a bit of time off work at the moment, so I've decided to revisit this, hopefully I can get it running this time.
The D-Link has a couple of options - bridge mode ( I emailed my ISP for help with settings but have yet to receive a reply, I just get a msg stating "no default route" when I attempt to use bridge mode), and also "PPPoE passthrough".
I was wondering if PPPoE passthrough might allow for the Modem/Router to function in modem only mode...anyone have any knowledge around this setting and whether it could help in this situation?
