sebastian76
Sep 21, 2018Follower
RBK50 with existing router
Hi,
I'm planning to buy mentioned kit RBK50, but i have important question and can't find clear answer.
Is it possible to configure RBR50 as normal AP without router function ? I have other r...
michaelkenward
Sep 22, 2018Guru - Experienced User
There is a manual for the Orbi WiFi System, including the RBK50, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Check the section Use the Router as a WiFi Access Point.
