slate2000
Jun 10, 2018Tutor
RBK50 with FiOS Quantum Router Setup
I have a FiOS Quantum router (G1100). I have the FiOS triple play so that includes internet, phone and TV with 2 STBs. I am interested in buying the Orbi RBK50 system. I want the FiOS router solely t...
- Jun 11, 2018
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
slate2000 wrote:
I have a FiOS Quantum router (G1100). I have the FiOS triple play so that includes internet, phone and TV with 2 STBs. I am interested in buying the Orbi RBK50 system. I want the FiOS router solely to act as a modem as I believe it is not very good but I own it. Also, the router supports Verizon features like the show guide and PPV. so I can't get rid of it. I want the Orbi to act as the wifi router with some limited hard wired devices attached. I see conflicting information regarding proper setup. Many say the Orbi has to run in AP mode, which I believe defeats the purpose. I have to believe that there are numerous existing and working situations like I highlighted (FiOS/Orbi). Before I buy the Orbi I need to know this will work and is the best way to connect with the FiOS router but yet use the full features of the Orbi. For sure, specific setup instructions for the router and the Orbi would be greatly appreciated. Many thanks in advance.... Johnny
Jul 07, 2018Guru - Experienced User
I would keep the Orbi in AP modem and let the FIOS router be your main host router...
Gellie wrote:
So if I'm using my Orbi in AP mode, is it beter to but my Fios route in bridge mode or just turn the wireless off? I still want to be able to use the Fios programing and DVR and PPV. Thanks
