ableman42
Feb 06, 2019Guide
RBK50 with FiOS, stopped working
Installed Orbi mesh system. Everything installed and was working great. Not sure it matters, but installed orbo firmware update. After that everything went south. Normal web browsing works fine,...
- Feb 06, 2019
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would recommend Option #3...
ableman42 wrote:
I don't need the extender, is that what you mean by "downstream router". Perfectly happy if it's just the Verizon router and the Orbi.
ekhalil
Feb 06, 2019Master
Not sure it matters, but installed orbo firmware update. After that everything went south. Normal web browsing works fine, but anything more intense (e.g. Sling on any device) won't start due to bandwith problems.
Unplugged everything and turned wi-fi back on verizon router, and everything works.
- Are you using wired or wireless backhaul?
- What type of wired devices do you have connected to Orbi?
- Please do the following simple test to check if you have double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
- Chuck_MFeb 06, 2019Mentor
How long had you had the system up and running before things stopped working? I am assuming a very short period of time (hours??)
- ableman42Feb 06, 2019Guide
Correct, very short. Maybe an hour? Not more than two.
Sean
Makes sense... please conduct the double nat TRACERT test that was described above and let us know if the first two IP addresses shown are private (192.168.xxx.xxx) or if only the first one is.
Open a command prompt and type in TRACERT 8.8.8.8 and hit enter. results should show instantly. Dont post them here because they would reveal your public IP.
A double NAT condition is caused by having a router attached to (downstream of) another router.
If you determine this is the case, it is not difficult to solve the issue, but we would have to know how it is configured first (e.g. what is the make/model of Cable modem -- or cable modem router combo the Orbi is attached to.
