j1odie's avatar
j1odie
Follower
Feb 10, 2023
RBK50 with Verizon FiOS G3100
So I just picked up this mesh system. I left the 3100 as is, connected a included CAT cable from the 3100 LAN to the Orbi WAN. Then I put the Orbi in AP mode, and then disabled all my wifi channels using Verizon app.
I rebooted both devices just in case. I can connect to the Orbi wifi fine, however, there's a significant drop off in speed and range compared to the 3100. Surely I've done something wrong? When switching to AP, I've made sure to auto handle everything from existing router.
I'm literally in the living room of my townhome and the Orbi is sitting in the kitchen, maybe 45ft away and I'm getting 30mbps compared to the 3100 giving me almost 200.
Any ideas?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello J1odie,
    Welcome to the NETGEAR Community!
    To add to FURRYe38,
    You mentioned that you just purchased your RBK50 Mesh System. The firmware currently installed on your system could be out of date causing network compatibility issues.  Please ensure that you are using the current version of firmware for your Orbi RBK50. When installing the most current firmware for your RBK50 which is FW version 2.7.4.24 ensure you upgrade the satellite first. After your RBK50 is updated remove all satellites from the network and check the speed that you are receiving from your RBR50 then add the additional satellites if necessary.
    Please navigate to the link below for the download file for your RBR50:
    https://www.netgear.com/support/product/RBK50#download
    For more information on manually updating your RBK50 please navigate to the link below:
    https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
    Please let me know if this helps!
    Best,
    Kevin
    Community Team
