dondeford's avatar
Jul 06, 2020
RBK50 with Xfinity Modem
I am installing a new Orbi RBK50 with satellite, plus a wall satellite and outdoor satellite from an old system.  I have Gig speed internet from Xfinity.  I put the Xfinity modem into bridge mode, then called Xfinity because they have to do some magic on their end because I had some Xfinity Pod extenders in the house.  With that done, I set up the Orbi, then rebooted everything from the modem to the router, to the switches, then devices.  Everything was fine at first, with all devices being assigned an expected 192.168.1.x IP address.  But then I started getting random devices assigned a 10.0.0.x IP address, like the router wasn't even there so they were defaulting to the modem, which, as I understand it, shouldn't have been giving out any addresses at all.  Any device assigned a 10.x address could not see the internet.  Anything with a 192.x gets internet just fine.
I rebooted everything again, and had a whole different set of devices assigned to 10.x, with some still assigned 192.x and working fine.  It is a combination of wired and wireless devices that get the 10.x addresses, and different every time I reboot, and sometimes randomly switching from 192 to 10 after running fine for a while.
I'm about at my wit's end on this.  I'm still renting a modem from Comcast because my phone comes from Comcast through the modem (lousy cell service where I live).  I think that the Orbi is a better router, so I would prefer to keep the modem in bridge mode, but I just can't make it work.  I'm close to giving up, turning off bridge mode on the modem and using the Orbi in AP mode.
I would really appreciate any thoughts on this.  The XFi extender pods just don't reach far enough, so I really need the Orbi system to be up and running.
  • Glad it's working well now.
    Please mark your thread as solved so others will know.
    Enjoy.
  • FURRYe38's avatar
    You'll need to check the modem to ensure it's fully bridged and the wifi has been disabled on the modem. If a 10.something address is being seen, psosible that the router on the modem got re-enalbed and Orbi will auto change it's IP address from 192. to 10 to avoid IP conflict with the modem.
    • dondeford's avatar
      dondeford
      Tutor
      My Orbi is running version 2.5.1.16.
      My Xfinity modem/router is their brand new WiFi6 model, but it doesn't say who manufactures it.  When I set it to bridge mode, I also called Comcast and asked them to turn off all router and WiFi functionality on their end, which they said they did, then they rebooted.  I could plug a computer directly into the modem and log in and it said that it was in bridge mode.  I can't think of anything else to do to get it fully into bridge mode.
      I'm ready to reset the modem, turn off bridge mode and put the Orbi into AP mode, but I'm sure the Orbi has a better router than Xfinity does, and I don't want to lose my guest WiFi functionality.
      • FURRYe38's avatar
        If you feel the modem is fully bridged. Then keep this configuration.
        Try some of the following:
        Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
        https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • michaelkenward's avatar
    michaelkenward
    dondeford wrote:
    I put the Xfinity modem into bridge mode...
    This isn't as straightforward as it seems. Some modem/routers are harder to configure than others.
    What device are we talking about here?
  • I've given up on getting the Xfinity router fully into bridge mode.  Each call to Comcast is an hour or two long, and it doesn't seem to fix anything.  I think it's because I had the XFi pods set up.
    I have the Orbi set to AP mode now, with the Xfinity router running things.  I lose some functions I liked, but I'm getting the coverage I need clear out to my shop and game room.
    Thanks for all the suggestions and support!
    Don
    • FURRYe38's avatar
      Enjoy.
      michaelkenward
      A lot of Orbi users do that. Many of us have better routers and the Orbi is there because it is better at delivering wifi.
