packsorted
Apr 04, 2020Initiate
RBK50V and Spotify Connect
My Orbi Voice doesn't seem to be working with my Spotify Premium. If I use the Spotify app on either an Android, Iphone or Ipad it can see the Orbi Voice under "Available Devices" but when I select the Orbi the app just says "Connecting" and never plays anything. Similar response from Alexa, I can ask Alexa on the Orbi Voice to play a song on spotify and she replies "Playing 'the track' on Spotify but again it never actually plays. Should also say I am using wire backhaul
Sort By
From the lack of response so far, my guess is that no one watching this forum has an Orbi Voice unit.
You may be more likely to get a solution by posting in the community forum devoted specifically to the Orbi Voice product:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Good Luck
- packsortedInitiate
Super thanks. Working now anyway, not sure what happened. Have a feeling there is some backend 'sync' between Spotify and Netgear. Just started working on its own the next day
Cheers
CrimpOn wrote:From the lack of response so far, my guess is that no one watching this forum has an Orbi Voice unit.
Good Luck
