LarsVervoort's avatar
LarsVervoort
RBK50v2 - no safe internet connection
Hi there,
Being an IT rookie, I am running into trouble installing my Orbi RBK50v2 pack with 1 router and 2 satellites. I have managed to install a part I think, as I have installed and renamed the network to which I can connect in my wifi settings. But when connected to the orbi wifi network and trying to connect to the internet, it does not work. In my browser I get a message that "no safe internet connection could be established."
Anyone any idea what I do wrong?
Thanks a lot
Lars
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Did you walk thru the setup wizard on the RBR with a PC and web browser?
    LarsVervoort wrote:
    Hi there,
    Thanks a lot
    Lars
    • LarsVervoort's avatar
      LarsVervoort
      Hi there,
      thanks a lot for your reply, but I am afraid you already lost this IT dummy there. I tried to set the system up via the app on my iphone, not via my desktop.
      To answer the rest of your questions, I am afraid you need to be a bit clearer.
      Thanks again!!
      • FURRYe38's avatar
        What Firmware is currently loaded on the RBR?
        What is the Manufacturer and model# of the ISP modem the Orbi router is connected too?
  • CrimpOn's avatar
    CrimpOn
    What browser are you using?
    Does this happen on all websites, or only on some web sites?
