OttoZed
Jun 13, 2018Tutor
RBK53 (1 x RBR50 Router + 2 x RBS50 Satellites) I need an additional RBS50 to work as an Extender
I purchased the RBK 53 Orbi mesh system to provide good wifi coverage in my home - it's specification claims wifi coverage up to 6000 sq. ft..
On the whole, I'm very pleased with my investment, but...
- Jun 13, 2018
There are two modes the satellites run in, extender mode connected directly to the router, or Daisy Chain, where one satellite would connect or piggy back of another satellite.
30 feet to start is a good adjustment to start at. The router can provide up to this by itself however depending on building materials, satellites may need be a bit closer. Top led should turn BLUE when it connects well then check connected devices for GOOD or Poor connection quality status on the routers web page.
I have 1 router and 1 satellite in my 5000sq ft home. 40 feet in between the router and satellite. However no brick.
Jun 13, 2018Guru - Experienced User
- OttoZedJun 14, 2018Tutor
Hi Furrye38,
Many thanks for your solution.
Connected one of the satellites to the other in a daisy chain configuration and managed to achieve a result!
I now have about -54dbm signal strength.
Again, many thanks.
Regards
OttoZed
- FURRYe38Jun 14, 2018Guru - Experienced User
Glad it worked. Enjoy. :smileywink:
- GizmoguycdnJun 24, 2018Aspirant
HI again,
I have exactly the same proble,. So I am looking at getting another RBS50 and make it daisy chain to my saletelite 2 but I see that there is a Netgear range extender (Nighthawk AC2200 X4S). Would the range extender work the same way as an additional RBS50 I would buy to extend the router range to Satelite 2?
