Mr-Lito
Apr 14, 2019Aspirant
RBK53-100PES WiFi dies
Its been working fine for about 3 months then it just died.
My WiFi dies as soon as it starts up. My mobile/AppleTv/iPads connects to it then it dies and comes back after a few minutes.. Then it dies again and keeps doing it.
Ive tried to reset it but makes no difference!
According the Orbi app it have the latest firmware.
Please help me! bought it in december.
RBK53 AC3000 with 2 sattelites
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mr-LitoAspirant
Hi,
first of all. IM not an IT techguy...
but all of your questions isnt relevent.
I havent changed a thing and it just stops working.
how do i get them replaced?
Please answer the question so we can better help you. It may not be a faulty Orbi, rather other issues that need to be explored. Questions are VERY relivant.
Mr-Lito wrote:
Hi,
