brandaopj's avatar
brandaopj
Follower
Aug 14, 2019
Rbk53 best placement for apartament onde floor
[img]https://i.imgur.com/Dl7ih1e.jpg[/img]
Hello,
I am about to receive the rbk53 kit and i am thinking the best placement for the router and satelites.
I´ve marked with red and orange the 2 possibilities for the router placement.
The orange is near the tv.
The blue is the satelites.
Any recomendations about settings to get the maximum performance?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Any Wifi Neighbors near by? If so, how many? Having many wifi nieghbors near by will be problematic.
    Try disabling the following:
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • Retired_Member's avatar
    Retired_Member
    Hello,
    Nice pic....your network will perform best IF the router is in the center of the home.  Sats can be moved closer if needed (magenta light).  Once you get the light to go out, leave them alone.
