0hleg
Mar 02, 2019Aspirant
RBK53 Connection issues. Help me get it working, last attempt before return.
I really want to use the orbi but after returning 2 products that were faulty in a row. I’m starting to get annoyed. I’m on my third now and might have to return this one too but I thought I’d give a...
ekhalil
Mar 02, 2019Master
Please make sure that you don't have multiple routers/DHCP servers in the network: Check that you either have Orbi as the main router or your ISP router but not both. What ISP modem/router are you using?
0hleg
ISP router? I don't have a isp router. I take the connection directly out of my fiber input. I don't understand what you mean.
- ekhalilMar 02, 2019Master
What is the device that covert your fiber interface into ethernet? Is it a "simple" ONT or a router?
- 0hlegMar 02, 2019Aspirant
I'm not sure what it's called to be honest. It's just a thing that sits on the wall with like 6 ethernet outputs. It's the first thing they installed when they dug the fiber. I can take a picture of it or you can tell me how i need to identify what it is haha
I will read the manual for a name hold on :)
- ekhalilMar 02, 2019MasterYes please, the manual should have the model name on it. If not please post a picture.
