0hleg
Mar 02, 2019Aspirant
RBK53 Connection issues. Help me get it working, last attempt before return.
I really want to use the orbi but after returning 2 products that were faulty in a row. I’m starting to get annoyed. I’m on my third now and might have to return this one too but I thought I’d give a...
DirkO
Mar 02, 2019Apprentice
Sounds like you are maybe doubble NAT-ing or something.
If you are using the router function of the orbi you have to make sure your ISP router is in bridge mode.
Option 1- Put ISP router in Bridge mode and let the Orbi be the router. (every ISP is different so we wil need some more info about your ISP before we can advise on how to do this.
Option 2- Put your Orbi in AP mode, restart and you should be good to go.
Cheers,
