hipertec
Apr 19, 2020Aspirant
RBK53 direct ethernet connect to satalite?
I have the RBK53 1 router and 2 satalites. My Orbi router is on one side of the house. 2nd one is about 20ft away center house 1st floor area and the 3rd one is on the 2nd floor on the other end of t...
CrimpOn
Apr 19, 2020Guru - Experienced User
Either or both satellites can be connected with ethernet. It should be pretty simple to compare the two configurations and see which gives the better coverage.
Good Luck
