hipertec
Apr 19, 2020Aspirant
RBK53 direct ethernet connect to satalite?
I have the RBK53 1 router and 2 satalites. My Orbi router is on one side of the house. 2nd one is about 20ft away center house 1st floor area and the 3rd one is on the 2nd floor on the other end of t...
hipertec
Thanks - what's the best way to reset all this on the Orbi? Is it to power off everything including the Orbi and modem.
Then modem boot and wait, then all the Orbis or just the Orbi router then wait 3mins... Then the satellites with the ethernet ports?
Also, best option both sats on ethernet on same side of the home but different floors?
CrimpOn
Apr 19, 2020Guru - Experienced User
This networking change should not require a "total reset". If one of the satellites is already in a location with an ethernet jack, just plug in the ethernet cable and wait a bit until the Orbi recognizes that ethernet is available and switches over. If a satellite will be moving to a new location, just unplug the satellite and move it. I would let it reconnect first over WiFi and then connect the ethernet cable.
When there is a reason to "restart everything", then yes. Power it all off. Modem on first (wait). Router on next (wait). Then things connected to the router.
