DaveJG
Jan 31, 2018Aspirant
RBK53 Ethernet Backhaul
wireless works great, but have not been able to get ethernet backhaul to work. connected with gigabit switch, updated to latest software....any ideas or experiences here? when I connect to ethernet...
DaveJG
Feb 01, 2018Aspirant
thanks. tried patience last night and it seems to have paid off...thereis a reset period of several minutes that seems to transpire before the internet comes back....
next question about this is if anyone has experience plugging other ethernet devices into the gigabit switch that is used for satellites. does the switch need to be dedicated to only orbi router and satellites or can other devices join in on the link?
budy
Feb 01, 2018Luminary
From what I could see in the terminal, the bridge is setup to prioritize traffic over LAN, so you should not have any issues, plus full ethernet speeds for devices connected to the LAN ports of your satellite - they will go directly down the LAN.
- DaveJGFeb 01, 2018Aspirant
Thanks Budy...planning to give it a go this weekend.
