esko1954
Aug 08, 2017Tutor
RBK53 networkwing with Cox Arris tg1682g
Cox just replaced their cable modem with Arris tg1682g. I would like to have one seamless network. Currently, if i connect a device to the router than it can't speak to any devices on the Orbi. Is...
DarrenM
Aug 10, 2017Sr. NETGEAR Moderator
Hello esko1954
You would have to look in the settings of your modem to find a modem only option this should allow you to use orbi as your main router.
DarrenM
