hipertec
Apr 02, 2020Aspirant
RBK53 router and 2 Sat ideal setting
Hi I just upgraded to the router and 2 sats from my old router only setup.  I have the router at the far end 1st floor and one sat at the middle of the house 1st floor, while the 2nd sat is on the 2nd...
Apr 02, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Armor, Circle. IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can turn down the power output of the RBRs wifi radios to see if this will help steer some devices to the RBSs under Advanced Tab/Advanced Settings/Wireless Settings. Most wifi devices pick and chose which signal to connect too based on noise, distance, signal quality.
Daisy Chain:
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain
- Retired_MemberApr 02, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle. IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).You can turn down the power output of the RBRs wifi radios to see if this will help steer some devices to the RBSs under Advanced Tab/Advanced Settings/Wireless Settings. Most wifi devices pick and chose which signal to connect too based on noise, distance, signal quality.
Daisy Chain:
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain:smileysad:
