cbc50-'s avatar
cbc50-
Follower
Aug 28, 2019
RBK53 since last firmware update ...
Since updating the firmware last week for our ORBI I cannot get live streaming on my iphone of our nest cameras. I get the connection... just no live feed.  Any ideas??
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed?
    What prior version of FW did you upgrade from?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • Anonymous's avatar
    Anonymous
    What firmware do you now have?  Why did you upgrade?
    Anonymous
    Any progress on this?
