comainusa's avatar
Jan 31, 2021
RBK53 v1 with firmware 2.7.2.102?
Hi there,
Does anyone know if the latest RBK53 firmware version 2.7.2.102 works with the RBK53 version 1 system (USB connector on back)? Netgear Orbi app only suggests 2.6.1.40 as available update.
Thx much in advance.
  • CrimpOn's avatar
    CrimpOn
    Yes, it does. I have it on two.
    • comainusa's avatar
      comainusa
      Tutor
      Thanks, CrimpOn - good to know. Did you expirience any kind of issues when switching to this firmware version? I'm trying to update my firmware (currently still on 2.5.1.16) due to issues with not showing all connected devices
      and random disconnects of one of the two satellites.
      Thanks much in advance.
      • CrimpOn's avatar
        CrimpOn
        No issues so far, but it is "early days".  I came directly from 2.5.1.16 (it's long and embarrasing story).  So far, nothing stands out.
  • FURRYe38's avatar
    Can be manually downloaded and manually installed which is preferred:
    https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2034115/highlight/true#M110640
    Update the RBS first before the RBR.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    comainusa wrote:
    Hi there,
