mdezrin
Feb 06, 2021Aspirant
RBK53V - Is the satellite w/Alex a full strength satellite?
I'm looking at the RBK53V mesh system. I'm intrigued because of Alexa and trying to find out if the satellite w/the alexa speaker is the same as the other satellites. When you look at add-on satellit...
Feb 06, 2021Guru - Experienced User
Its a prett good deal. I recommend it frequently.
The alexa satellite is a RBS40V. It has the 866mbps backhaul of the other satellites (other than the 50 series).
the 50 series use a 1733mbps backhaul so have a little better backhaul. Theres not a whole lot of difference in performance though.
I've used both 50 series, 40 series, and the alexa satellite and don't notice any difference in performance unless i'm doing max speed testing. And then its only noticable if hardwired into the satellite.
- mdezrinFeb 06, 2021Aspirant
THANK YOU!!!!!!
That is exactly what I was missing! I was like damn this looks to good to be true. And it kind of is. But in a good way. 40 vs 50 is fine and I missed that nuance. What a price difference on buying a 2nd 40/Alexa satellite (currently $99) vs. a 50 satellite ($239)!
Do you know the difference between the Orbi Pro WiFi 5 (SRK60) and the RBK50s?
Thanks.
- plemansFeb 06, 2021Guru - Experienced User
hardware wise, they're the same. The SRK50 is more designed for business class and includes business class features/support.
