akhilstyle
Jan 21, 2022Tutor
RBK753 iOS Devices intermittent disconnect
Hi,
I have a weird intermittent issue where various iPhones intermittently disconnect from my wifi for 5-7 mins. The wifi icon keeps spinning and there is no internet on the device.
It automatically reconnects after a few minutes.
I have a video - https://youtube.com/shorts/_ARFkysdnPA?feature=share
Thanks
Thanks
What firmware is on the router?
And the firmware on the satellites?
What gateway is it connected to?
Is it only iphone/mac's with issue? Or does windows/android devices have problems as well?
- Hi,
Thanks for your reply. It only seems to be iPhones. I have 2 with the same issue. iPad seems ok.
Router 4.6.5.14
Satellite 4.6.5.14 as well
I just upgraded them to this firmware. I had the issue even on previous firmware’s.
It happens about once every 2 days or so.
Thanks
Akhil- plemansGuru - Experienced User
have you tried disabling the private wifi or random mac feature on the iphones?
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
