CDELL801
Nov 02, 2021Aspirant
RBK753S in AP Mode
Just installed my Firewalla Purple, set my Orbi RBK753S in AP mode and it looks like all of the wireless connections are just going to the main RBR750 and none of the satellites have any wireless connections to them anymore, they do show online and good connection and when looking at the network map in the app, the wirless devices now far away from the main router have a poor signal, is this normal in AP mode? Are the satellite's now only good for wired connections? Firmware Version V4.6.5.14_2.0.54
CrimpOn wrote:Changing from router mode to access point (AP) mode causes the entire Orbi system to reboot. This might be a case of lots of frantic devices saying, "Where did my WiFi go?...... Oh, THERE it is." and connecting to the router because it is the first unit to begin broadcasting the WiFi SSID.
It might be interesting to power cycle some of those devices that 'should' be connecting to a satellite and see where they connect.
I have tried that, but I have not rebooted all of the orbi's since I setup the Firewalla Purple. Maybe I will reboot them and then try the devices again, but should they show up under the satellites connected devices?
- CDELL801Aspirant
For your future needs, Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
