Retired_Member's avatar
Retired_Member
May 19, 2021
RBR 40 cannot factory reset
My RBR 40 router jammed yesterday and factory reset does not work. I have tried two ways to do reset, via factory reset button on back of router or try logging in via Orbilogin.net, neither methods work. Irritating since the system is just a year old and should not die this early. Any idea how I can get this reset?
  • CrimpOn's avatar
    CrimpOn
    The Orbi did not revert back to the settings printed on the product label after clicking the "Erase" button? (see attached image)
    How long was the reset button pressed? (I find it takes at least 8-10 seconds before the Power LED begins to flash amber)
    • Retired_Member's avatar
      Retired_Member
      No I am not able to log on the router so cannot press Reset button and cannot reset with a needle on the back of the box. Looks like I am stuck with a router that is not working and unable to reset.
      • FURRYe38's avatar
        So you can't press the reset button at all or pressing the reset button doesn't reset the RBR?
