lfd346's avatar
lfd346
RBR 50 Firmware
Can someone tell me the correct firmware for the RBR50 I have v2.5.0.38
it appears to me there is a newer version but mine says no? Of course my support expired and have had problems ever since! Thanks in advance
    • lfd346's avatar
      lfd346
      Thanks I tried to manually update it and it told me it was the wrong one! I guess I will wait for it to be forced out! Thanks
      • CrimpOn's avatar
        CrimpOn
        Hmmm.  After downloading the two files, you have to "extract" the .img file from each .zip file.
        Then, go into the Orbi web interface, Advanced Tab, Administration, Firmware Update, and then select the "Manual Update" tab.
        Can you provide the full name of the file that it rejected?
