Kookookoojoo
Dec 09, 2020Follower
RBR 50 Streaming Isssues
RBR50 Firmware Version V2.5.2.4 Sound repeatedly cuts in and out watching Netflix; Router port directly connected to Samsung 1080 tv. with 5 patch cable. Previous advice to ...
Dec 09, 2020Guru - Experienced User
Be sure your using CAT6 LAN cable.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Try updating to v40:
Or downgrading to v16:
Factory reset and setup from scatch after applying either FW version.
- vajimDec 10, 2020Master
"what firmware is loaded?".......................................V2.5.2.4
