tomistrugar
Dec 16, 2022Aspirant
RBR10 firmware not updating
I tried to manually update the satellite of my RBR10 via the web interface to the firmware version 2.7.4.24 (currently it's V2.7.3.22), using RBR10-V2.7.4.24.img, but the system gave the message: "...
- Dec 16, 2022
And just like that, it all worked.
I tried updating the satellite's firmware via its web interface and this time it worked and rebooted the satellite.
The router's web interface also confirmed the satellite had been updated to the V2.7.4.24
I then manually updated the router via the web interface and it too updated to V2.7.4.24
So all is good now 🙂
CrimpOn, thanks again for your input. Knowing about the RBR vs RBS firmware really helped. Have a great day!!
CrimpOn
Dec 16, 2022Guru - Experienced User
That "R" indicates firmware image for the RBR10 router. Download the RBS10 image.
tomistrugar
Thank you, CrimpOn.
I downloaded the RBS10-V2.7.4.24.img
But when I tried uploading it in the Manual Firmware Update Admin web interface (after selecting the Satellite) I got this message flash up:
"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
The ORBI app, the web interface auto firmware check, and the manual firmware upload are all not finding/rejecting the V2.7.4.24 update.
What to do?
- CrimpOnDec 16, 2022Guru - Experienced User
After extracting the image from the zip file, I usually connect directly to the satellite using the IP address shown on the Attached Devices page. (same login as the router: "admin" plus password). Select the bottom menu item, Firmware Update.
- tomistrugarDec 16, 2022Aspirant
Thanks, CrimpOn, didn't know that the satellite had its own web interface.
But I connected to it, uploaded the RBS V2.7.4.24 firmware, and hit update, and after 10 minutes it is still NOT updated (web interface said it should take 1-2 min, see screenshot attached).
The router web interface says that the satellite is still on the previous firmware V2.7.3.22
Has anyone been able to update RBR/S10 to the V2.7.4.24 firmware?
I personally think there is a bug somewhere that's stopping the firmware update from being applied, and only Netgear can fix it.
Is there a way to escalate this to Netgear tech support?
The community forum exists to a large degree because Netgear provides '90 days of complimentary support' with an original purchase. After that, customers can either pay a Netgear subsidiary (called GearHead) or can search the internet for clues. There is a popular forum on Reddit and this Netgear sponsored community forum. I came to the forum when my system was a little over a year old to ask about something that puzzled me, and some really nice people helped me out.
Very puzzling. What people often do is get out a paperclip and stick one end into the tiny "Reset" hold on the back of the satellite ro 10-15 seconds. Then try again after it reboots.
