jbwheat's avatar
jbwheat
RBR10 Router to AP mode
I have just recently purchased an Orbi Mesh system. The RBK 13. It is supposed to be here in 2 or 3 days. I was checking into how to setup and saw that I need to set the Router in AP mode since I wil...
  • FURRYe38's avatar
    Apr 20, 2020
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    jbwheat wrote:
    I have just recently purchased an Orbi Mesh system. The RBK 13. It is supposed to be here in 2 or 3 days. I was checking into how to setup and saw that I need to set the Router in AP mode since I will be hooking it up to a Cable Modem Gateway with the WiFi disabled. Do I do this prior to setting up my network with the Mobile app or should I do it afterwards? I know this is probably a dumb question, but I want to do this right the first time and I don't really have any experience with this sort of thing. Thanks in Advance for your help.
