whysodifficult's avatar
Feb 09, 2021
RBR10
Simply need to know how to get password for Orbi app , which does not accept "password" as default.  When I enter forgot password, I get a 404 not found error.
  • CrimpOn's avatar
    CrimpOn
    The Orbi "app" uses the Netgear account login, usually an email address and password, the same as used to access this community forum.
    • Thanks but I had to change the password for the device. My issue with the system is that the Orbi app does not recognize my internet connection even though the lights on the router and satellites are blue.
      Since I have installed this system I have had questionable service as I am losing the connection at times. That never used to happen.
      Also my Google Home will not work since I have set up the system
      I have the syste hooked up to Verizon G1100 router.
      I am thinking of returning the system as I did not have these issues before and the only reason I purchased it was to increase the signal to my TV in the basement .
      Thanks
      • vajim's avatar
        vajim
        Master
        don't use the app
        IF you need to check your network, login using a PC
        wow....this may be part of your problem as well:  Verizon G1100 router.
        the orbi is a router + Verizon G1100 router is a router = 2 routers....NOT good
