wrh42
May 04, 2019Follower
RBR20 & RBS20 Firmware 2.3.1.58
My RBR20 now has Firmware 2.3.1.48 installed, but it lists Firmware 2.3.1.58 as available. I have been doing manual updates because of various problems I've had with the automatic update system. To p...
May 06, 2019Guru - Experienced User
Files have not been posted to the download site as of yet. I presume NG will post them when they get ready.
Some release info:
V2.3.1.58 Release Notes: [Bug Fix] Fixes the issue where the time zone can't sync with the satellite. [Bug Fix] Fixes issues with the guest network control using Alexa. [Bug Fix] Includes security fixes.
Blanca_O
May 06, 2019NETGEAR Employee Retired
The FW 2.3.1.58 has the following changes :
• Fixes the issue where the time zone can't sync with the satellite
• Fixes issues with the guest network control using Alexa
• Includes security fixes
The said firmware is for RBR40, RBS40, RBR20, and RBS20.
