guycarmin
Nov 14, 2019Aspirant
RBR20 devices connecting to 2.4 GHz
Hi,
I have the Orbi RBR20.
I've connected it and configure - now I see that all of my devices (Window Laptop, Linux Laptop and several Galaxies (S7-->S8+) are all connecting initially to the 5Ghz and then moving to 2.4Ghz.
I've seen that also whit my laptop and cell-hone while siting 2m from the router (the main).
Please advice,
Guy
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- guycarminAspirant
Hi - Thanks for replying so fast ;-)
Firmware V2.3.5.26
The hous is about 1,800 SQ/Fit on 3 flors.
The Router and (currentally) one Satellite which are phisically connected with CAT7 LAN, and are one floor up and about 10 fit aside.
I have one neibghour 2.4GH wifi but from wifi scanning it's not interfiring (from channles and strength perspective.
I've already enabled Beamforming, MIMO and WMM.
just disabling Daisy Chain, as I've already disabled all the rest.
The point is that all of my devices (2 laprtops, several Galaxy phones and 2 tablates) all connecting to 2.4Ghz.when connecting to the network - they are connecting to the 5Ghz, but then they (ALL) migrationg to the 2.4Ghz. It's happans even if I'm 2ft from the router. Also - when I'm on the second flor I see another wifi with the same SSID with no password - and when I try to manually connect to it I'm getting the 5Ghz (but then the device goes back to the 2.4).
Thanks,
Guy
"The Router and (currentally) one Satellite which are phisically connected with CAT7 LAN, and are one floor up and about 10 fit aside" 10 feet? If so, then this is too close between the RBR and RBS. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
