Jpatullo's avatar
Jpatullo
RBR20 dropping internet and satellites losing connectivity
I have this same problem (wifi dropping, satellites losing connection to the router).   My router is running the latest firmware V2.7.4.24, I have two satellites.  This system has been rock solid for just over 2 years, it has been wildly inconsistent the last month.  thanks for any advice.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    ️What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Circle, Traffic Meter.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Jpatullo's avatar
      Jpatullo
      Thanks for the feedback.  I was able to rectify the situation by a hard reset of the modem, router, satellites, then resynching the satellites.
