MartienR's avatar
MartienR
RBR20 Ehternet port doesnt't work after firmware upgrade
I installed the newest firmware to my RBR20 (v2.5.1.16). After the reboot of the system, the ethernet port on the router doesn't work anymore. I have attached a netgear gs105 switch attachted to it. Any ideas?
  • Issue solved. When I connected a device directly (without NG gs105 switch), it did work. Problem was the switch. Bought a new one (TPLink) and everything works again.
    • FURRYe38's avatar
      Interesting, what rev version is the GS-105 switch? Was the switch just bad?
      Glad you got it resolved.
