GolfingArtist's avatar
Jun 04, 2020
RBR20 Firmware Update & Smart TV Problem
Yesterday I downloaded the latest firmware update (Router Firmware Version V2.5.1.16) and after doing the update my Samsung TV is connected to my Orbi Wireless Router / Mesh yet cannot get to the internet. Everything was fine before the update. I have rebouted my internet service, rebooted the Orbi and reset the network access on the TV all to no avail. Does anyone have a solution to this problem?
  • FURRYe38's avatar
    Glad that worked. Mark your thread as solved.
    Enjoy.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? Try this...
    • GolfingArtist's avatar
      GolfingArtist
      Tutor
      My internet service is Xfinity / Comcast and my cable modem is a Netgear Nighthawk CM1150V.
      • FURRYe38's avatar
        Affter the reset,
